Turning Point Hustler 3-Blade Modular Prop / Aluminum, 13.25 dia. x 17 pitch, RH
Stainless steel performance at aluminum prices. Hustler modular propellers have a unique blade geometry that offers unmatched cornering, acceleration, boat handling, and top speed. Tuned vents provide a fast hole shot and get you on plane more quickly. Higher rake angles tighten the vortex produced by the propeller, adding to boat lift and overall performance. High flow-through barrel exhaust system on the Hustler prop maximizes exhaust flow and increases top end speed, while progressive pitch angles increase fuel economy. Long-lasting, glossy powder-coated finish is designed to resist corrosion. This is the propeller with blades only. Hub Kits are sold separately. Turning Point Part Number: 21431711 Applications: 40 - 150 hp engines, 4-1/4" Gearcase Diameter: 13.25" Pitch: 17" Right Hand Rotation
